Engine stall when breaks epc light turns on after stall
so when I start the car it come right on but once I drive a little and press the brake the car stalls then takes a few try’s to start back up and when it does ecp like comes on and stays on till I park and turn off for a while
One way the car stalls is if there is a leak in the brake booster, either by a blockage of the vacuum hose or a cracked, ruptured or leaking diaphragm. Another is the master cylinder leaking brake fluid, either internally or externally from the cylinder boot. Stalling can also happen if there is a brake line obstruction, either by a chunk of rust or a pinched brake line. Air in the brake fluid from a hole in the system can prevent proper pressure to the brakes. The car may also stall due to a vacuum leak in the anti-lock brakes system.
Screper
01-13-2009 10:10 AM
Krzych
09-09-2003 08:30 PM
