Error Code - Check Engine Light
Old Aug 23, 2002 | 11:15 PM
cxavier's Avatar
New Member
Default Error Code - Check Engine Light
My check engine light came on for the first time tonight. Wasn't doing anything other than normal driving. I checked it with my friends PocketLogger and the error code said "Secondary Air Injection System Incorrect Flow Detected" What does that mean? I have a 2000 A4 1.8TQ, does anyone have any ideas?
Old Aug 23, 2002 | 11:38 PM
JAFO's Avatar
Default as far as i can determine.
only reference i find is air injection at cold start. to reduce emmisions. if so it's not a big problem. if under 50K mi. should be covered.
Old Aug 24, 2002 | 04:04 AM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
Default Probably just the intake hose came off of the SAI pump. Very common.
tgil is correct, the SAI pump is used during the cold start, to pump air to behind the exhaust valves, to lean out the exhaust that is generated by the rich run condition at this time.
Old Aug 24, 2002 | 10:32 AM
JAFO's Avatar
is that the bridge in jackson NH in your sig
Old Aug 25, 2002 | 04:08 PM
Head Cat Herder
25 Year Member
No, it's in Taftsville (east of Woodstock) Vt...
maximumdownforce
Jan 20, 2009 05:37 AM
DuvalDino
Dec 4, 2008 08:50 AM
audilover917
Audi 100 / A6 (C4 Platform)
May 22, 2007 09:29 PM
gcheddar
Sep 10, 2004 01:10 PM
