Check engine light code...
Old Dec 3, 2008 | 03:47 PM
DuvalDino's Avatar
Default Check engine light code...
P0411
Secondary air
injection system
incorrect flow
would this be the MAS or something else?
Old Dec 3, 2008 | 03:49 PM
JohnLZ7W's Avatar
Default probably need to rebuild the secondary air pump
<ul><li><a href="https://forums.audiworld.com/tt/msgs/1574799.phtml">https://forums.audiworld.com/tt/msgs/1574799.phtml</a</li></ul>
Old Dec 3, 2008 | 03:54 PM
DuvalDino's Avatar
Default Re: probably need to rebuild the secondary air pump
Thanks, should this cause any problems if not fixed immediatly, or will it go away when it warms up and the seal expands?
Old Dec 3, 2008 | 04:07 PM
HellooMcFly's Avatar
Default I'm dealing with the same thing right now...
I already rebuilt my pump but the code keeps coming back, going to try a new solinoid and kombi next.
Old Dec 3, 2008 | 04:08 PM
Default wont cause problems...
the pump turns off about 2 minutes after you start the car you can hear it, you just have to live with the cel on if you ignore it.
Old Dec 4, 2008 | 08:50 AM
sTTickman's Avatar
Default Might want to make sure your hose it not broke. Any leaks could give
you a cell also. And that flex hose can become pretty brittle.
Hybridpower
May 12, 2015 12:30 PM
vitamin
17
Apr 14, 2014 03:26 PM
maximumdownforce
Jan 20, 2009 05:37 AM
germantoy
Nov 3, 2005 06:31 PM
cxavier
Aug 25, 2002 04:08 PM
