Fusebox question...
Is there a problem here?
I know, stupid question but I dunno much about electrical stuff but is there something wrong with putting in a 10 amp fuse on something that originally had a 5 amp fuse.
Thanks.
Anyhow...more likely than not that 5 Amp fuse was there because that was the max current they wanted the phone device to draw...but to play it safe you could dump a 5 A fuse back in there. 5A fuse makes for 69 Watts...your 10A makes for fusing at 138 Watts...do you think your boost gauge has a 138 Watt lightbulb inside? ;-)
Regards,
James R.
2001 A4 1.8TQMSXP (StopTech A4 Brakes, StopTech SS Front - AWE SS Rear Lines, Oettinger Pedal Set + Dead, Oettinger RE's 17x8, Yoko AVS Sports 225/45/R17, European Xenon Housings, Bailey BPV & RS4 Grill)
The add-a-circuit I found was only available in the mini size which can only use a max fuse of 10 amps.
If this is a problem, I may have to hunt down the bigger version add-a-circuits.
Thanks.
Anyhow 10 LED's at 20mA MAX each would be 200mA say toss on another 200mA for the rest of the circuit (way to generous) and you're drawing like 400mA I'd say a 1 or 2 amp fuse is what you should run 10A is waaaaaaaaaaaay to high the board would be smoldering on fire in front of you and the fuse would never even think about blowing...trust me.
Regards,
James R.
Must've been hitting the pipe the day he wrote it
or was I reading that wrong?
Regards,
James R.
Regards,
James R.
