Gonna DIY replace my coolant resevoir Saturday morning. Anybody have any tips?
Seems pretty straight forward - but if there is any advice or tips, pass 'em on.
My current resevoir has some cracks...<ul><li><a href="https://forums.audiworld.com/a4/msgs/2355698.phtml">https://forums.audiworld.com/a4/msgs/2355698.phtml</a</li></ul>
very easy. Most people disconnect it for oil changes
Drain the coolant then its just 3 screws. Unclip the wires from undernneath and disconnect the hoses and your all set. Then work backwards through the steps.
seems straight forward, remove 3 screws, unplug sensor wire...
unclamp two hoses...catch coolant(or turkey baster it out beforehand)
i believe the 2.8 tank is the same as the 1.8t tank btw.
<img src="http://www.modifieda4.com/images/dipstick-tube/DSC00109.sized.jpg">
what I'd do
drain coolant from bottom of radiator on drivers side... rear of radiator.
drain it just enough so that the coolant tank is empty.
replace bottle
fill with half water/coolant mixture.
replace bottle
even easier, just pop the small hose off of the tank, since you need to anyway...
let it drain out into your waiting container... you'll want a hose clamp and a cork/bolt/something to block the hoses after you remove the tank..
c4S6
Audi Original "S" Cars
06-22-2007 12:59 PM
jp110099
10
09-29-2006 01:28 PM
Blown Nogaro
9
07-15-2003 06:02 PM
