Is the Greddy III turbo timer the only one that supporst our factory alarm?
I believe, it's dependant on how you wire the turbo timer to your car.
Since your car is a '97 model, if you follow the turbo timer install in the "Tech" section of AW, you should be fine if you used a turbo timer other than Greedy. BTW, I wired my Apexi Auto timer using the info in the "tech" section and don't have any issues with the factory alarm.
-Narson
-Narson
Got the greddy IV(Matches all after market guages in car) and it works fine with the factory alarm
NOW, the bitch part is trying to find someone who knows which wire coming out of the ecu is the speed wire.. I spent a good month looking to see if anyone knew.... but no luck... if you find it, post PLEASE! I'm not the only one looking for it.
My bro just installed his APEXi TT in his GSX. I actually like it better, has more functions like Air/Fuel Ratio and some other stuff. but that just means more wires to find that no one knows about...
N2M_S4
06-23-2001 01:47 PM
shorki
04-14-2001 08:49 AM
