HARDCORE ENTHUSIAST'S, ANY INPUT???
Guest
Posts: n/a
I have decided to go with the 1.8t (unhappy to find that the letherette is not avail for the
sport seats)...but anyways, i have not decided if "2000" is my way due to the fact 98's
are going for nearly10k less. i would greatly appreciate any input on the differences
between 97-2000 models (1.8tqs) interior, controls,anything...(it all makes a dif.) also,
sport steering wheel.....stereo volume controls or not? thanks much!!!!!!!!
Guest
Posts: n/a
Re: HARDCORE ENTHUSIAST'S, ANY INPUT???
By my recollection, there was an additional heat shield that was added around the turbo around mid-98. I think the wastegate problem also 'fixed' around mid-98. I have an early '98 but no problems so far.
tom
1.8TQMS
tom
1.8TQMS
Guest
Posts: n/a
Buy a 97-98, misinfo on the shield...
The turbo's are identical, the oil line got a new C-shaped shield instead of an L-shape. A NON_ISSUE if you run synthetic.
A very small, but annoying number of 97-98-99 turbos had a wastegate rod fail. It is under warranty, and if not obviously modified will likely be under hidden warranty for life. If not, it is a simple fix and doesn't harm the motor/turbo if it does break. Audi replaced the whole turbo, but the rod is ancillary.
Jason Weaver
07-09-2003 02:34 PM
AudiOx
07-31-2001 07:42 PM
Ben Singapore
05-10-2001 11:26 AM
