Has anyone installed ProtoColD's RS6 Xenon kit?
<center><img src="http://pictureposter.audiworld.com/7091/ignitor.jpg"></center><p>This is the one that is being sold on the classified section. I've got everything together except the ignitor seems awefully big. It's on right now with not much room to spare. Also, I cannot get the back cover back onto my headlight housing (btw, they are halogen ecodes). Am I doing something wrong? The corner of the ignitor is resting on the bottom which brings up an issue of how I'm going to aim the headlight. Any ideas? I bought this kit thinking that everything will fit back together easily.
You can take off the tin casing on the ignitor off, which may give you some room...
also try putting the ignitor on a differenat way. Meaning try and get the ignitor on so that the bottom or top of it is parallel with the housing.
I had the same problem, but squeezed them in.
i can take a pic for you in a bit... off to dinner!!
what are you talking about?
you dont drill a hole for the wire, you drill a hole for the ballasts plug that feeds into the housing from outside.
<img src="http://flyservers.registerfly.com/members5/d2shid.com/images/ecode_upgrade_pic_10.jpg">
There's no way to line up the ignitor so that the top is parallel with the housing
because the two nubs on the bulb will only fit into the ignitor a certain way. You can see it in the pic below that there is a cutout at the 2,5,8 and 11 o'clock positions. I did take off the tin case and it gives a little more room. I still can't get the back cover back on without it hitting the ignitor. I'd really appreciate it if you wouldn't mind taking a picture of yours.
<img src="http://pictureposter.audiworld.com/7091/ignitor3.jpg">
<img src="http://pictureposter.audiworld.com/7091/ignitor4.jpg">
Looking at the ignitor, I think I could dremel out 2 new slots at 3 and 9 o'clock so that I could put it on so that the top and bottom are parallel to the housing. The black piece that you see on top is very thin and the white part underneath actually has a slot. What do you guys think?
No need to dremmel the H7 adapter...Put bulb in housing. That adapter clicks on. (more)
Put bulb in housing...take that adapter and twist it on...its lil tricky b/c there is a lock on it so u have to twist it on right. but u should need to cut that at all.
