Hate splicing? Don't want to solder? Want one-touch rear *UP*? New technique!
Old 07-17-2002, 09:12 AM
Junior Member
pikejerky's Avatar
Default Hate splicing? Don't want to solder? Want one-touch rear *UP*? New technique!
<center><img src="http://pictureposter.audiworld.com/34747/onetouchrear.jpg"></center><p>
Rating difficulty on a scale of 1 to 10 this is a 2.
See Peter Harren's one touch up rear window tech write up and follow step 1. Then do what is indicated in the picture above. Re-assemble.
Push down and hold window button for 10 seconds then pull up and hold for 10 seconds to let the window controller re-learn the one touch operation.
Enjoy.
This has been tested on a 98 and an 00 but of course YMMV. Small needle nosed pliers are handy for wrapping the pins.
One difference between the fronts and rears now is that with the key off the rears are still one-touch but the fronts are not.
Anyone know if this is just a design quirk or if there is a good reason to disable the one-touch feature if the key is out but the operator is still in the car? I couldn't think of one.
Old 07-17-2002, 09:14 AM
bugbbq's Avatar
Default *waiting for work to be over*
oooooo! I can't wait to try this out!
Old 07-17-2002, 09:20 AM
Longwolf (Christian)'s Avatar
Whoa.....I may need to try that.
Old 07-17-2002, 09:25 AM
nanotech's Avatar
Default Pinch protection is also maintained for all windows
At least for the 00 car, I haven't had the courage to test it on my 98 but it should work.
Member
wnut's Avatar
u da man!
Old 07-17-2002, 09:27 AM
jason in toronto's Avatar
i recommend a small faq for this - fantastic
Old 07-17-2002, 09:31 AM
bugbbq's Avatar
Default I'll test it...
I've got a test penguin I can use
Old 07-17-2002, 09:45 AM
Rest In Peace
markbradford's Avatar
Why a thmall one - go for a big flaaaaaaaaaming one!
Old 07-17-2002, 09:50 AM
Member
wnut's Avatar
Default gapina!!!
why not your neck? =)
Old 07-17-2002, 09:54 AM
Junior Member
pikejerky's Avatar
Default I tries it on my hand and it doesn't take very much pressure at all
he would be fine assuming it works :0
Quick Reply: Hate splicing? Don't want to solder? Want one-touch rear *UP*? New technique!
