Headlight Problem
Old Nov 12, 2006 | 09:43 PM
Redditt81kg's Avatar
New Member
Default Headlight Problem
Hello all, I have a 2001 1.8TQ. I installed a Mcculloch 8000k HID kit about a year and a half ago I have had no problems at all until recently. At first only of the lights would come on and I would have to flip the switch on and of for it to come on and it would'nt always be the same light they would alternate. I checked the wireing and all seems good but I am no expert. I haven't changed the bulbs yet but since the problem alternate between lights I didn't consider that an option. Now both lights come on but after a minute or two they both will go dim. If I flip the switch they will be full strength but a minute of two later same thing. My voltage is good and doesn't fluctuate nor do my dash lights dim just the headlight. I just wanted some opinions before I go replacing stuff. Thanks in advance.
Old Nov 12, 2006 | 10:03 PM
JAFO's Avatar
Default this sounds a little like a headlight switch problem.....
also known as a combiswitch. this tech may help or search for combiswitch.<ul><li><a href="https://www.audiworld.com/tech/elec114.shtml">https://www.audiworld.com/tech/elec114.shtml</a</li></ul>
Old Nov 13, 2006 | 09:14 AM
ChooChooNongNongHead's Avatar
Default did you run new dedicated ground wires to the ballasts or are you using the OEM wires?
sounds like a grounding issue.
vlocity
A4 (B8 Platform) Discussion
Dec 5, 2016 10:42 AM
JGood
Jun 16, 2014 04:49 PM
Snow Trooper *Swiss*
Oct 15, 2006 08:03 PM
TTuned
Feb 19, 2005 07:01 PM
neuf
Jan 28, 2003 04:00 PM
