Heater Core Flush
Old Nov 16, 2008 | 06:43 AM
pmc_73's Avatar
Default Heater Core Flush
I'm not getting the heat out of the car I used to. So I decided to flush the heater core.
- I popped off both lines to the heat core, hooked up a small shop vac and sucked all of the coolant out of the system.
- I then ran 2-3 more gals of water though the core 1-2 gals going in each direction. The water didnt seem to flow as quickly as it should (it seems like it is still blocked).
I still dont have very good heat. The lines leading to the core, the driver side one is HOT, the other is only warm(the one /w the pin hole). I think this would say the core is still plugged up. Are there any good products that would losen up the stuff inside the core?
btw.. '01 - 1.8t AWM
thanks.
--patrick
Old Nov 16, 2008 | 07:14 AM
Aarononymous's Avatar
not really if it's that bad....did you see lots of hard deposits in the water you flushed?
Old Nov 18, 2008 | 01:16 PM
pmc_73's Avatar
Default Re: Heater Core Flush
After a bit of work, I got some heat.
I picked up a bottle of Prestone Super Radiator Flush. Again, I disconnected the 2 hoses on the heater core, /w a small shop vac + small hoses + duct tape (to seal the hoses to the core), I drained the heater core of the G12. Then ran 1 gal of hot water to rinse all of the G12 out. Then ran 1 gal of hot water + the cleaner, and chuncks of rust and other stuff came out, so the stuff really works. Ran another 3 gal of hot water to ensure all of the cleaner was removed. Bled the heater core (there might be a few more air bubbles as I hear gurggling noises from the core).
Thinking of repeating the process and to clean even more of the crap out. Not so chilly anymore!
clix00
A4 (B7 Platform) Discussion
Dec 8, 2015 10:22 PM
thall6594
Oct 25, 2013 07:25 AM
DFS
May 16, 2007 04:21 AM
'01 S4 Kid
Jun 14, 2006 02:58 PM
