Helmet with or without sunroof? Help tall folks!
Guest
Posts: n/a
When I get my 1.8T I'm pretty sure I'll go to a couple track days. I figure I'll just use my motorcycle helmet ... will I fit? Does the sunroof make a difference? Can you drive the track with the sunroof open for clearance? I'm 6'3" and will probably barely fit. Thanks!!
Guest
Posts: n/a
I am 6'3" and autocross with a helmet...
In the autocross seating position where the seat is very upright, the top of the helmet does touch the top of the roof. I don't think opening the sunroof is going to help much, since you will be further to the left. It doesn't touch enough to make it a problem, and if you sit in a certain way, it doesn't touch at all. Therefore, I wouldn't worry too much about it.<p>Mike
Guest
Posts: n/a
It's kind of a problem for me, and I'm only 6'0"....
I have to hold my head at a slight angle, so that the helmet goes in the sunroof area. At the events I've been to, you can't have the sunroof open.<p>You can try reclining the seatback farther than you normally would and sliding the seat forward a little; you'll just have to play around with the adjustments until you find the best position.<p>Rich D.
Guest
Posts: n/a
You guys gotta remember, it's not just height...
...it's also inseam. If you're 6'4" but have a 42 inch inseam, headroom will not be an issue.<p>Personally, I'm 6'2" with a 34" inseam, a 1.8t with sport seats and a sunroof, and I don't fit well in the car with a helmet on. It's certainly doable, but I have to tilt my head 10 degrees -- kind of a PITA. The car is so great in so many other ways, though, that I don't mind.<p><br>-vik<br>99.5 1.8tqms
kj
Motorsport Discussion
06-18-1999 02:54 PM
James R.
02-23-1999 02:41 PM
