help...
Old Jun 17, 2004 | 07:53 PM
SpeedyDTP247 CQ+UrS4's Avatar
Default help...
<center><img src="http://pictureposter.audiworld.com/69531/a4.jpg"></center><p>how is that black license plate holder held on? cuz i took out those 2 screws but its like glued on, or is there screws on the back side? i need to take it off to help reduce rattles. if theres no screws on the back side and its glued on, whats the best way to reinstall it?
speedy
Old Jun 17, 2004 | 07:58 PM
JCF's Avatar
JCF
Senior Member
Default to reduce rattles?
I don't understand. Taking that off would if anything increase rattles between a plate and bare metal instead of plastic.
Old Jun 17, 2004 | 08:03 PM
MikekiM@PureMS's Avatar
Former Vendor
Default Held on with goo..
Just pull real hard.
It helps to pull it off when it's warm to soften the goo.
Old Jun 17, 2004 | 08:26 PM
Default Re: to reduce rattles?
i have dynamat type stuff on the license plate it self and on the license plate frame that i have on there. i have notice when i hold down on either bottom corner of the black license plate holder it reduces the rattle.
speedy
Old Jun 17, 2004 | 08:52 PM
DougR's Avatar
Junior Member
The car *would* look better with no rear plate.
Old Jun 18, 2004 | 05:08 AM
stidrvr's Avatar
New Member
Default STOP!!!!!! --->
dont try to take it off you will either break it or, well break it. I barely got mine off and come to find out Audi uses a super duper sticky sounddeading material on the plate holder. Your rattles arent coming from you plate holder, maybe your plate. Try double sided foam tape on the back on the licsense plate. If that doesnt work then you have to use sounddeading material on the back side of the trunk skin. Thats where my rattles are coming from. There coming from the trunk skin the the support piece that runs along the skin to give it strenght. Take off the carpeting and you'll see it.
Old Jun 18, 2004 | 09:59 AM
Boba Fett's Avatar
AudiWorld Expert
25 Year Member
Default Here
<ul><li><a href="https://forums.audiworld.com/a4gen2/msgs/413512.phtml">https://forums.audiworld.com/a4gen2/msgs/413512.phtml</a</li></ul>
1T42T (aka ZZ CETT)
Sep 25, 2005 12:34 AM
Apr 27, 2004 01:33 PM
tshaw
Feb 27, 2003 12:45 PM
NYImola::NYMisano
12
Apr 24, 2001 09:13 AM
jdulac
Apr 20, 2000 08:08 AM
