Help With Boost Problem?
Old Oct 29, 2002 | 04:00 PM
Llama's Avatar
Default Help With Boost Problem?
Here's the situation. I got an APR chip with a TurboXS BPV. When in 5th gear, WOT doing about 65. The boost gauge reads up to about 15psi, then start jumping between 15-20. I've check the BPV (replaced with factory), and the N75 valve. Both 'seem' ok. Any bright idea? I could jsut take it in to the factory and say "Hey I got wacky boost around 17psi" DOn't think that would go over too good :-p
Old Oct 29, 2002 | 04:42 PM
Sal R.'s Avatar
Default Boost spike. Quite normal. Just means that your turbo is building boost...
...faster than the wastegate can keep up.
It should settle down down to 15-18 psi.
If it's still fluctuating at WOT, you may have a problem w/ your wastgate.
Old Oct 30, 2002 | 03:50 AM
Llama's Avatar
Default Re: Boost spike. Quite normal. Just means that your turbo is building boost...
Thanks Sal. Yea, at WOT, it still bounces. Never though of the wastegate. Anything I can do to check it? Wonder if the dealer could look at it under warrenty... <ponders>
Thanks again
Boosting1Bar
Jun 10, 2002 10:43 PM
neonhero
May 27, 2002 01:06 PM
NorthWestQuattro
Apr 9, 2002 01:11 PM
Kid
Aug 14, 2001 03:39 PM
shorki_07
Apr 3, 2001 10:14 PM
