Help with Boost problem, and error code please..
Old May 5, 2003 | 08:56 AM
VenomousA4's Avatar
New Member
Default Help with Boost problem, and error code please..
I have recently installed a new Hose that runs from the intercooler to the intake manifold. A while after I installed it i started getting an error code.."17536 - Fuel Trim: Bank 1 (Mult): System too Lean" Ive searched and it seems this error code coresponds with either a maf problem, or a vacum line. Also, now when im running full throttle, ill stay at my stock 9 lbs of boost, untill I hit about 4500 rpm and then my boost slowly falls to about 6-7-psi. Is this normal?? Also, does anyone know what my error code might be a result of..i would assum i might have a leak in the hose i bought. Any ideas or suggestions would be awsome. Thanks.
Old May 5, 2003 | 09:12 AM
Audi2ptzero's Avatar
Elder Member
Can be bad plugs or a maf that is going bad.
Old May 5, 2003 | 09:49 AM
Quattroleap's Avatar
Junior Member
That's the code I got right before my TB controller unit die
Old May 5, 2003 | 10:03 AM
QuiksilverS4's Avatar
When I got that code I also had minimal boost. Fix was relace vac line to the BPV
Bumble bee
Jun 27, 2013 06:53 PM
StreetCrawler(Cole)
Jul 21, 2006 10:57 AM
Audone
Jul 6, 2005 06:36 AM
R32Mathieu
Mid Atlantic Discussion
Jun 29, 2005 08:28 PM
FinnTT
Oct 10, 2003 08:21 AM
