Need help with a code! Code 17536
Old Jul 5, 2005 | 07:35 PM
Audone's Avatar
Junior Member
Default Need help with a code! Code 17536
<center><img src="http://pictureposter.audiworld.com/19251/imgp0249.jpg"></center><p>I didnt write down the explanation, but it was something around "Bank Too Lean"
Lately the car has been stalling when starting, and seems to take forever for boost to build. I can give it gas when it is about to stall and that usually works, but I have to sit and wait till it warms up. When its warm it runs fine, just doesnt build boost as fast.
The car is a 98 1.8T stage 3 with the usual supporting mods..
Pic for views!~
Old Jul 5, 2005 | 07:46 PM
mobaar's Avatar
Member
pretty common problem IIRC, check the vac lines
Old Jul 5, 2005 | 07:53 PM
JA4T's Avatar
Member
Default other than a vac leak..
it can be a dirty or faulty MAF. You can take that out and clean it to see if that helps. Sometimes it calls for replacement.
J
Old Jul 6, 2005 | 04:22 AM
CURSH's Avatar
Default Haha, I remember making your sig.
a bit has changed since then it seems.
Yeah, Vac Leak I believe.
Easy enough to fix.
I need a whole new set of vac lines.
Old Jul 6, 2005 | 06:36 AM
Laughing Gnome's Avatar
Member
I had that a couple times, no leaks but a dirty MAF was the problem
C5867
Aug 16, 2006 10:41 AM
FastTTnb
Mar 3, 2006 07:07 AM
JPRobertsons
Oct 11, 2005 12:20 AM
VenomousA4
May 5, 2003 10:03 AM
M3iRiSH
Sep 6, 2002 02:36 PM
