Help: Electrical Issue
His high beams work, but only when he pulls the stalk. Turn signals, low beams, horn, wipers all are not operational. Fuses are okay.
I have been reading that several people have had similar issues, and in some cases, these have turned out to be the signal stalk. How can I tell for sure?
My guess is the load reduction relay for the X contact. It's the second relay in the bottom row.
Try measuring the voltages on the pins of the relay:
(1) 85 - chassis ground. Should be 0 V against chassis, R = 0 Ù against chassis.
(2) 87 - output voltage. Should be + 12 V against chassis when ignition is on. If it it not but all others are OK, it's the relay.
(3) 30 - input voltage. Should be + 12 V against chassis at all times.
(4) 86 - ignition sense (from ignition/starter switch). Should be + 12 V when ignition is on.
That should help you tell whether it's the relay or its wiring.
