HELP - middle of brake pad replacement.
Guest
Posts: n/a
I replaced the front pads and rotors without problems. In the back, though, I am unable to retract the caliper piston. I read the FAQ, and I'm doing it right, but I have been turning and turning, and it doesn't appear to retract. It needs to go back quite a bit as the rears seem pretty worn compared to the front. The car only has 20,000 miles on it.
Any suggestions?
Paul Clowser
98.5 1.8tqms, ATE PowerDiscs, Mintex RedBox (front only, so far)
Any suggestions?
Paul Clowser
Guest
Posts: n/a
You may need to push/turn very hard.......
I took unbelieveable inward pressure while turning to retract my pistons. I almost broke every bone in my hand trying to push in and turn. I even constructed a tool to fit the piston notches and my wrachet wrench (Pep Boys may also sell a tool that fits). The special Audi tool the techs use pushes and turns with great force to perform the job very easily.
Just keep pushing and turning. It will eventually grab and go in. Try going out further first and then back inward...that seemed to help me. Good luck!
Guest
Posts: n/a
Oh the pain of it!
I was all sorts of sore after changing the back brake pads. You have to push very hard and turn at the same time. Even with one of those cheesy special brake tools that fits into the notches of the piston, it was extremely difficult. It takes a tremendous amount of pressure and turning to get those rear pistons back in.
As a result? I don't think I'm ever gonna touch rear brakes again. I'll pay someone else, thank you.
Warren
Warren
Guest
Posts: n/a
Thanks, All. I tried everything you suggested. Finally, I opened the bleeder valve...
It worked immediately. The other side was just fine without opening the valve. I have only driven the car 10 miles, so I can't give any impressions yet. I'll post 'em later.
Thanks, again.
Paul Clowser
98.5 1.8tqms, Mintex RedBox all around!
Thanks, again.
Paul Clowser
ado_dado83
03-13-2007 01:48 PM
BrianG
14
11-30-2002 05:06 PM
jvosney
08-30-2002 04:12 AM
S4Rye
07-01-2002 07:05 PM
