Here's a crazy question that I've never seen asked before: Will THESE fit on my A4?...
Old Aug 9, 2001 | 09:45 PM
jussnb's Avatar
Default Here's a crazy question that I've never seen asked before: Will THESE fit on my A4?...
<img src="http://www.wheelenhancement.com/Ruf18.gif">
They're 18" RUF wheels, and I happen to think that they'd look awesome on an A4. But I have no idea if the Porsche bolt pattern & offset is the same as the A4.
Is anybody up for PhotoShopping a set onto a black A4 for me?
Old Aug 9, 2001 | 09:48 PM
dingster's Avatar
Member
Default No. IIRC Porsche hubs are 5x130 and has very low offset. H&R does have wheel adapters that'll
make them fit the Audi bolt pattern. However adding an adapter like that is like adding a really thick spacer and with the already low offset they'll stick out like crazy.
Old Aug 9, 2001 | 09:52 PM
jussnb's Avatar
Very interesting. Thanks for the info.
Old Aug 9, 2001 | 09:55 PM
bugbbq's Avatar
Default I've seen many porsche wheels that fit a VW jetta.
so they can't be that off.
Old Aug 9, 2001 | 09:59 PM
dingster's Avatar
Member
Default Are you sure those are not the MM replicas?
Those "Cup" wheels are replicas drilled for cars from other makers but they're not real Porsche wheels. Unless they're redrilled Porsche wheels. I would never put a redrilled wheel on my car.
They could be mounted with adapters but on the A4 significant work has to be done to the fender to avoid rubbing.
jussnb's Avatar
Default Now that you mention it, I've seen some too. Man, that RUF design would look so sharp on my car...
I wonder how much those things run? Probably a small fortune.
Old Aug 9, 2001 | 10:01 PM
bugbbq's Avatar
Default 100%
got pics to prove it somehwere here.
jussnb's Avatar
No, they're the real deal. Hopefully someone will be able to find a pic...
Old Aug 9, 2001 | 10:05 PM
dbtong's Avatar
Default i'm thinking these wheels are gonna be pretty wide...
although i guess it's possible you could buy 2 sets of the fronts only. the rear ones HAVE to be fat...and phat...for the porsche.
Old Aug 9, 2001 | 10:06 PM
dingster's Avatar
Member
Default Do you know which Porsche wheel?
I've seen many on VWVortex... the turbo wheels, cup1s, cup2s but all of them were replicas. You can't differentiate them by looking at them.
Like I said it's possible to do so but it would be much more cost effective just to get the replicas. Then again I doubt there are any replicas of the RUF wheels.
