How do you go about fixing heated mirrors that are always Heating?
not true. they're on at 59F degrees and below. there's tech. bulletin regarding the fix of these,
but I'm eating lunch, so it'll have to wait for me to find it. It's really not a fix, but how to test if it's failing beyond a sensor failing that can be checked by looking for error codes.
I just had my driver's side one replaced this past tuesday due to the heat function not working. No sensor failures, but the element failed or never worked. The only fix is to replace the entire "guts" of the mirror, since everything is attached.
Technical Bulletin on heated mirrors --->
<ul><li><a href="http://cory.charltonfamily.org/gti/vwtechcontent/audipdf/a660004.pdf">http://cory.charltonfamily.org/gti/vwtechcontent/audipdf/a660004.pdf</a</li></ul>
