How to reprogram remote door opener control unit????
Now that its clear, hold your garage remote a few inches from the autolink remote. Hold both the button on the Autolink that you want to program and the garage remote button at the same time until it blinks fast. That should do it. (But it didn't on mine)...onto the next step.
If your garage door opener has rolling codes, you'll need to do this....
On the garage door opener unit, there is a button that you can press to erase any existing codes (keeping the button held down for like 5 seconds) or press it for like a second to put it in 'learn' mode. Press this button for a second, then go to your Autolink remote and press the button that you wnat to program. That should do it. I had to do it a few times because my remote would typically not work until I was very close to the door - very tempermental. but once I got it done, the Autolink signal is much better than the remote that came with the opener.
Oh yea, I think your car needs to be turned on while you are programming the Autolink!
