I am excited..... I got the ball running on stage3+.... waiting for a quote...
hopefully it'll be reasonable and I won't have to do it myself...
A funny detail is that the stage 3+ does not include a high flow cat... ??!!!?
Yup
APR Investment Cast Inconel Exhaust Manifold
Garrett/Allied Signal Ballistic Series Ball-Bearing Turbocharger
APR High Flow Catalytic Converter
APR Custom Cast Urethane and Silicone Intake Hoses
APR High Flow Fuel Injectors
All Associate Plumbing and Hardware
couple comments...
The fit of the APR S3+ on my car was/is pretty poor. not sure if that is the case on all s3+'s but that was the case here. For example, the inlet pipe on the turbo is too big and pushes against the headlight. wrong orientations on hoses, and some other issues. Most importantly, there were no instructions given.
You will need the carbonio intake for that kit.
What clutch are you running?
Other then that it pulls strong, i'll know more later since i just picked it up today.
I'll see what I'll need to get.... I don't think carbonio is a must as far as function goes, but it
might be good for getting it fit right...
FMIC, etc. will also need to be decided soon. I'll use my stock clutch until it starts to die.
skip carbonio... i've glued better **** together then that..
the carbon fibre is well done, everything else... well home depot is a massive place im sure they could have rigged something better up
