I know this sounds weird, but could I call someone about a K04 install or get someone to write me a
good response. I have everything off and the turbo moves. The banjo bolt for the coolant line is still on and theres no way to get it off where it is right now. I cannot get the turbo to pull out. The oil return line is snagged up and with two people we still cant get it.
I just lost my second and I dont know what to do. Any help is appreciated.
TIA
ps my number is 971 506 3890 if anybody thinks thats easier than the internet.
TIA
the coolant line to the block is just a soft rubber line...
its like the line top of the coolant resivor. Just use some vice grips to compress the clamp and then pull the rubber line off. When you do this coolant will probably come out. The way I have removed the oil line is probably not the best way but it has worked for me. Disconnect the line at the oil pan and make sure it is clear. Move the turbo to the left to clear the exhaust manifold and then give it a jerk upwards. If you have a second person I would have them watch the line but I've done it myself and been fine. Once you make it past that first few inches you can easily wiggle it out.
phoneyman
11-05-2007 12:58 PM
dhbiker1
12-22-2006 07:38 PM
TJHUB
07-30-2005 11:02 AM
Gjaime
11-25-2001 12:30 PM
