I searched already... Need help removing the center console trim around radio etc...
<center><img src="http://pictureposter.audiworld.com/71680/touareg_torch.jpg"></center><p>How can I remove this. Is it clipped on? I am afraid to attempt as it looks really brittle.
TIA
TIA
You need to pull a couple screws
There are two one behind each side of the radio, you will need to pull the radio out, there might be one in the ashtray area. Don't remeber for sure.
Then just pull from the top and un-clip it
just one of those long pointy ended metal nail files
they work perfectly, or else a sabersaw tip with the teeth filed off. i just use a nail file, go pick one up for like 50 cents at a drug store.
