ICM, coilpack, or sparkplug?
On my way home from work today my car would misfire around 2800rpm if I stepped on the gas hard but no CEL. I took it to a friend and checked it with a VAG-COM and no fault codes right away, but finally got a few (see below)when I finally threw a CEL. I am not sure what my problem could be...I replaced all 4 spark plugs and the coilpack on cylinder 3 roughly 3 or 4 weeks ago. The first time I had this problem, it went away after putting in new spark plugs. But then it came back about 2 days later so I changed the coilpack on cylinder 3 since I had my car checked and I knew where it was misfiring. After the new coilpack, CEL went away and everything was fine for the past few weeks. Now I am back to square one. Anyone have any ideas based on these codes? Thanks in advance...any help is greatly appreciated.
5 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16687 - Cylinder 3: Misfire Detected
P0303 - 35-10 - - - Intermittent
18014 - Rough Road/Engine Torque Signal from ABS: Electrical Malfunction
P1606 - 35-00 - -
P0300 - 35-00 - -
P0303 - 35-00 - -
5 Faults Found:
P1606 - 35-00 - -
P0300 - 35-00 - -
P0303 - 35-00 - -
Re: ICM, coilpack, or sparkplug?
Have you checked the ICU (ignition control unit). I had a similar problem and it was the ICU. I replaced it with a OEM replacement which cost me $128 (no tax or shipping) and car is running fine. Thera are a couple of tech notes on this matter. There is also a way to check your ICU (again check tech notes). Replacing the part took me about 5 minutes. Good luck.
Where did you find a replacement for $128? Dealer told me it was $380 for a new one...
last time this happened and yes I am aware that you can test it. I made an attempt at it last time but it didn't seem like it was working out very well for me.
Turkz617 (04-17-2021)
