Ignition Coil Results - Squeak Noises - Question??
Well, IRA dealership would only replace the faulty coil - they don't have enough to replace all of them at the same time. Looks like I have to wait for a "letter" from AOA in order to have all of them replaced.
As far as the squeaks from the tires - they "lubed the front end of the car". Makes me wonder how long this will last. So many responses have told me its probably the control arm or sway bar bushings. Wondering if I should try and push the issue since the car is still under warranty. WILL THEY INSTALL THE CONTROL ARM KIT while the car is under warranty.. Does anyone know????
The lube DID quiet the noises.
Alas - the lube DID quiet the squeaking. I do not hear any squeaks whatsoever. They also replaced the rear brakes and rotors. I have now had all the brakes and rotors replaced on the car. The car has only 26K on it and I NEVER ride my brakes. Was told they wear quickly. No noises to date = will let you know if it comes back. Hopefully this is the end of it.
anotheraudiowner
22
10-15-2017 10:34 AM
aurum
03-30-2007 01:47 AM
m4rcus?
02-04-2004 09:21 AM
Red'97A4
11-08-2002 06:51 AM
