ignition coilpack replacement
Old Oct 14, 2002 | 10:11 AM
crystalA4's Avatar
New Member
Default ignition coilpack replacement
is there a how to on replacing the coilpacks
Old Oct 14, 2002 | 10:14 AM
paul_858's Avatar
AudiWorld Expert
Default quick and dirty...
step 1 pop the hood
step 2 remove plastic engine cover(screw driver or phyiscal thumb pressure and turn the 3 plastic screws till they pop up)
step 3 locate faulty coilpack cylinder. 1 is the closest cyl to you, followed by 2, 3, 4(closest to firewalls).
step 4 disconnect the wire attached to the top of the coil pack.
step 5 remove bolts if applicable holding the coil packs in place.
step 6 gently pull the coil pack out vertically.
step 7 replace everythign in reverse order.
step 8 start the car, go for a drive.
Old Oct 14, 2002 | 10:45 AM
crystalA4's Avatar
New Member
Default Re: quick and dirty...
thank you very much
arjun90
Jan 28, 2026 08:47 PM
WithanF
May 16, 2008 08:12 PM
MHA4
Apr 8, 2003 06:19 AM
Bob Petruska
Feb 9, 2003 01:29 PM
Bob Petruska
Dec 16, 2002 09:57 AM
