I need a crash course in changing 3.0 coil packs???
Old Dec 15, 2002 | 02:38 PM
Bob Petruska's Avatar
25 Year Member
Default I need a crash course in changing 3.0 coil packs???
Anyone remove and replace the coil packs on the 3.0 V6? Looks like you need to remove all 3 on one side at the same time and then remove the bad one.
If you have done it I would appreciate a step by step procedure before I attempt it and break something!
Old Dec 15, 2002 | 02:52 PM
ErikNYC's Avatar
Member
Bob, Question for you, YGM
Old Dec 16, 2002 | 01:32 AM
PlacitasNM (aka Ken)'s Avatar
Member
Default Did you see this post by lawong. I would think the 3.0 CP replacement would be very similar.
<ul><li><a href="https://forums.audiworld.com/a4gen2/msgs/204443.phtml">https://forums.audiworld.com/a4gen2/msgs/204443.phtml</a</li></ul>
Old Dec 16, 2002 | 07:57 AM
25 Year Member
Default The 3.0 requires the 3 coils be removed as a one piece set initially....
I was hoping someone removed them and would give a little insight as to what problems occurred when trying to pull 3 coil packs off the sparkplugs at one time. The cable connecting the 3 together doesn't seem to have much slack and you can't remove the coil pack connector off any given coil pack until all 3 are removed from the engine.
Old Dec 16, 2002 | 09:57 AM
Member
Someone posted something on this a while back. It'd probably take a 2 hr. search to find it though.
bilbo6209
Sep 9, 2015 01:28 PM
S4intheOC
Sep 8, 2015 12:12 AM
anticsAK
Sep 6, 2015 05:34 AM
anticsAK
Sep 4, 2015 09:59 PM
aron56
Audi 100 / A6 (C4 Platform)
Sep 1, 2015 12:39 AM
