ignition control module fix
Old Nov 4, 2004 | 02:16 AM
Quattrocket's Avatar
Default ignition control module fix
ok, so my ICM went the other day and i am taking a shot at fixing the old one... so i got the cap off only to see that the whole unit inside is covered in silicone. how do i get the silicone off to solder inside, and does it matter that the silicone is gone after i am done???
Old Nov 4, 2004 | 02:47 AM
Mat Indukts Lambos's Avatar
Banned
Default You're talking about the module that mounts to the airbox?
I'm not 100% sure, but if you're asking these questions, I'd say the chance of you successfully rebuilding that control module for less than the cost of a new one are pretty slim.
I can get you one for around $113 IIRC.
1-866-684-3900.
Old Nov 4, 2004 | 03:41 AM
qfrog@work's Avatar
Senior Member
unless you are a f/t student... its not really worth it imo.
Old Nov 4, 2004 | 05:42 AM
turboprincess's Avatar
New Member
Default Re: ignition control module fix
Look up the threads for turboprincess. I fixed this about a year ago and it still works. and yes you must remove the thermal gel from around the pins or it will be tough to reach the heat needed to solder.
Old Nov 4, 2004 | 07:45 AM
BSCA4's Avatar
Default I fixed my and it still work fine after 1 year. I do not recommend it to who do not have access ....
to good solder tool
Old Nov 4, 2004 | 07:46 AM
BSCA4's Avatar
Default Use an exacto knife slowly remove the gel around the disconnect terminal and transistor. Use a .....
very hot solder and alot of solder to make sure they contact well.
Old Nov 4, 2004 | 12:31 PM
Default Re: You're talking about the module that mounts to the airbox?
yes thats what i need! i tried calling your number but it said that the # cannot be completed as dialed. i live in canada would you be able to ship???
Old Nov 4, 2004 | 06:34 PM
Banned
Default Sure, we've dealt with quite a few canadians already.
1-866-684-3900, or try 1-410-684-3900. Maybe the toll free number is for U.S. only. :-/
Try again tomorrow? Or email me, with payment info & shipping address.
 Pouria Savadkouei
 Michael S. Palmer
Old Nov 5, 2004 | 09:39 AM
Banned
Default Got an update on that part......."retail" is $386......
and that's what we're to sell them for. Give me a hollar and we'll see if we can't work something out.
brian5s
Q5/SQ5 MKI (8R) Discussion
Mar 13, 2019 05:39 PM
ragnarg
Jan 23, 2017 04:41 AM
K-solo
Mar 30, 2004 02:15 PM
A4dp
Feb 27, 2003 10:18 AM
abcdefghijklmnop
Oct 4, 2002 12:03 PM
