Ignition switch problem.
Old Jul 9, 1999 | 09:51 AM
Rusty
Guest
Posts: n/a
Default Ignition switch problem.
Has anyone had a problem with the ignition switch, steering lock, not engaging when you remove the key, the other drawback is it thinks the key is in the ignition so you can't remotely lock the car. I'm wondering if some of you have had the problem and if there was a simple fix, otherwise it's off to the dealer<br>
Old Jul 9, 1999 | 10:57 AM
DaveN
Guest
Posts: n/a
Default Try a little graphite powder in the lock...
it is a dry powder that comes in a tube. Put the nozzle of the tube into the keyhole and squeeze. You can get it at most hardware stores. Then put the key in and work the lock. This is likely to fix it, if not it's dealer time.
Old Jul 9, 1999 | 11:17 AM
JJ-WI
Guest
Posts: n/a
Same problem for the first two weeks I had the car, then it went away on its own
Old Jul 9, 1999 | 12:17 PM
Grandma Dynomite
Guest
Posts: n/a
Default Try a little gunpowder in the lock....
It's some dry grey powder that comes inside ammunition. <p>Pack gently with a q-tip, insert short fuse, light with match and run.<p>Then take it to the dealer - i'd pay money to see exressions on their faces.
Old Jul 9, 1999 | 01:33 PM
DaveN
Guest
Posts: n/a
Could be entertaining.
prijedor
May 19, 2009 08:12 AM
axe_360
Nov 8, 2007 05:27 AM
audijim113
Audi 100 / A6 (C4 Platform)
Nov 5, 2002 04:13 PM
cytoe
May 11, 1999 07:41 AM
D Stratemeyer
Nov 5, 1998 06:25 PM
