I'm working on something for the noobs that are yet to learn DIY
I'm going to start with the AEB/ATW/AWM
Objective is to have an online reference for part numbers
here is the begingings of it. Please post what you would like to see added to this list.
LOF (3-5K)
Oil Filter 068-115-561-B
Seal N-013-849-5
SVC (15-20k)
air Filter 058-133-843
pollen filter 8a0-819-439-a
plugs PFR6Q or 101-000-063-AA (NGK double platinum) BKR6E-11 (NGK copper)
Coolant (G12)G-012-A8F-A4
B5-AWD
Fuel Filter 441-201-511-C
seals n-013-812-8
2Xeach n-013-814-9
B5-Fwd
Fuel Filter 1h0-201-511-a
clamps 2X n-024-122-2
LOF (3-5K)
Seal N-013-849-5
SVC (15-20k)
B5-AWD
seals n-013-812-8
2Xeach n-013-814-9
B5-Fwd
thats the idea.... post items you guys would like to see
I'll eventually list all of them by engine code... so you can just ask for the parts by number
diverter valve part numbers
ignition amp module part numbers
ignition coil part numbers
all that sort of stuff.
Nice but Ihope you aren't deluding yourself into believing noobs will use it.
IMO , it will get used more by vets referring noobs to it when they ask for part information. I'm sure many noobs find the forum FAQ but look how many don't bother searching.
All in all it'll be a good resource for folks tho ...
like
BYPASS VALVE 06A-145-710-N
P/S FLUID G-002-000
BRAKE FLUID b-000-700-a1
SILICONE SPRAY D-007-000-A2
tonight I'll do the rest of the fluids
manual trans
auto trans
differential
torsen
P/S FLUID G-002-000
manual trans
auto trans
differential
torsen
In all honesty, even though I have my very own copy of ET*A at home..
I almost NEVER need to use it... My parts sources dont use the Audi numbers a lot, they just know the parts by name. If I have a part which needs replacing in hand, I just read the number off of it. Good parts guys don'w want you to come in with number in hand, nor do they need you to come in with number in hand.
