injector problem?
Old Dec 7, 2004 | 03:02 PM
jimsi3's Avatar
New Member
Default injector problem?
so, my CEL(flashing) came on and my car was shaking(drove real slow, no power)
my local shop diagnosed it as an injector and changed it and then it went out again. any ideas wht this could be? coils were checked, new spark plugs.
also my car smells like exaust when the heater is on, any ideas about this too? have been to the stealership 6 times for this problem
Old Dec 7, 2004 | 03:05 PM
Yippers®'s Avatar
Member
Bad coolant temperature sensor?
Old Dec 7, 2004 | 03:21 PM
jimsi3's Avatar
New Member
Default Re: Bad coolant temperature sensor?
how would that cause the problem... which one? im confused
Old Dec 7, 2004 | 03:25 PM
Tom Serrago's Avatar
25 Year Member
I would suspect the ignition control module, is this an AEB?
Old Dec 7, 2004 | 03:35 PM
jimsi3's Avatar
New Member
Default Re: I would suspect the ignition control module, is this an AEB?
'99 1.8tq
Old Dec 7, 2004 | 03:40 PM
25 Year Member
Common problem on the AEB. Did the shop change the injector at #2?
Old Dec 7, 2004 | 03:50 PM
jimsi3's Avatar
New Member
Default Re: Common problem on the AEB. Did the shop change the injector at #2?
i'm not sure which one, is there something i should mention to them?
Old Dec 7, 2004 | 04:04 PM
25 Year Member
Default Tell them you suspect the ICM, and they should pull codes too.
16684 random cyl misfires or 16686 #2 cyl misfire seems to be the most common. A bad coil pack or injector will throw that code too. Swap coil packs then check codes if the code shows a different cyl then that coil pack is bad, if it is still #2 it's more than likely the ICM.
It's on top on the air filter box.
 Michael S. Palmer
Old Dec 7, 2004 | 04:05 PM
Yippers®'s Avatar
Member
Default You made it sound like swapping the injector took care of the CEL but that now the car smells of
fuel, especially when the heater is on. If the coolant temperature sensor was lying to the ECU by saying the engine was stone cold when it was actually fully warmed the ECU will add fuel as part of its cold start up routine. The results can be pig rich conditions until the long term fuel trim finally sets a DTC and lights the CEL.
It is on the firewall end of the engine. Search here will provide ample posts about changing it out.
Old Dec 7, 2004 | 04:08 PM
25 Year Member
He may have multiple issues.
