Integrated garage door opener...
Guest
Posts: n/a
I noticed on the http://www.seansa4page.com/ that Sean was able to take a "dead button" and turn it into a garage opener. He doesn't have any details on how to do it though.<p>I have a 99.5 2.8QMSA and I have one "dead button" available, I think it is the ASR button, which is not needed since I have Quattro.<p>I was wondering if anyone else out there has done this and what the procedure is.
Guest
Posts: n/a
Some Answers...
The dead button is really nothing more than a spacer. I purchased a second Defroster button which is the only momentary switch available for the dash. I opened up the switch and removed all of the internals except the wiring for illumination and power. The voltage had to be dropped in order to get it down from 12v to 9.3 volts for the remote. I ran two wires out of the switch to the remote's circuitry which I placed inside the boost gauge housing on my dash. In essence the defroster switch replaced the push button switch on the remote's board.<p>This ended up being a more complicated project than I had planned and since I had someone else handle the rewiring I did not get a good set of instructions documented nor did I get photos of the project. This is one project that really needed them. :-(<p>I originally had the remote circuitry stored in the small compartment on the right side of the buttons but found that the remote range was unacceptable. By placing it inside the boost gauge housing it was as good as before. One thing to be aware of is just how complicated the circuitry inside the defroster switch really is. I was amazed and it took a little bit to figure out what all was going on.<p>Hope this helps a little.<p>Sean<br>97 1.8Tqm<br>99.5 1.8Tqm<p><ul><li><a href="http://www.seansa4page.com">Sean's A4 Page</a></li></ul>
marko681
07-24-2006 03:03 PM
Troy H
09-26-2005 11:46 AM
deplach
10-11-2002 04:27 PM
