Intercooler Upgrade
Old Jun 10, 2001 | 02:42 PM
takai's Avatar
New Member
Default Intercooler Upgrade
A friend of mine just sold me a used greddy roughly 24 inch for real cheap. Any way before I go ripping my front end off to plumb the damn thing, what should I know about software etc. I will be going with an upgraded turbo before to long. This is some forethought. Thanks for any and all comments.
Old Jun 10, 2001 | 02:44 PM
James R.'s Avatar
Default You should know that it won't work w/o software changes ;-(
All of the FMIC's require software work on the 00+ cars. If you leave the OEM piece in place and hook them up in series then you may not have this problem...
Regards,
James R.
Old Jun 10, 2001 | 02:48 PM
takai's Avatar
New Member
Default so by leaving the stock with all the fixings then I might be ok?
I will be getting a apr stage one chip by the end of the month, should I tell them? Thanks for the reply
Old Jun 10, 2001 | 02:53 PM
James R.'s Avatar
Default Well it MIGHT work...
I've heard some other makes of FMIC's which are meant to be series connected who claim it will work just fine like that. I don't know if you're aware but APR has plans to release a really nice FMIC for like <$1000 and they will do the software to go with it.
Regards,
James R.
Old Jun 10, 2001 | 03:01 PM
takai's Avatar
New Member
Are you chipped yet/ if not do you plan on it?
Old Jun 10, 2001 | 03:19 PM
EdP's Avatar
EdP
AudiWorld Uber User
Default What I've been told was....
The pressure drop is less than stock, so it wouldn't require a software change. The problem is the "new" boost sender at the outlet side of the stock IC. If it reads a pressure drop more that it's calculating for, then it assumes there is a leak, and falls into limp mode. Swapping out a FMIC won't necessarily require new software unless it causes a drop more than stock. It must also have a bung to accommodate the sender unit. This also applies to the 2000MY.
Old Jun 10, 2001 | 03:24 PM
James R.'s Avatar
Default I've done the whole chips and K04 thing before...this time I think I'm just going to skip to the big
turbo kit bypassing all that other crap. I know how the chips and K04 perform and I know it won't be enough for me...so I'm holding off till I can afford the whole package. In the mean time my car is totally set up for the added power ;-)
Regards,
James R.
Old Jun 10, 2001 | 03:57 PM
Dead's Avatar
Elder Member
Yep ,he even got it in primer so he doesn't peel the paint off when he goes hyperspeed.. ;-)
 Michael S. Palmer
Old Jun 10, 2001 | 05:02 PM
James R.'s Avatar
Ahh Mr. I Hate Silver rears his head again ;-) Baaaa Baaaa goes the sheep...
Old Jun 11, 2001 | 03:21 AM
Dead's Avatar
Elder Member
Default I don't HATE it.....
.....looks good on y'all.
LJH
9
Nov 28, 2006 03:14 PM
AvantMnkyA4
21
Oct 4, 2006 04:32 PM
fourwheelslide
9
Nov 6, 2005 05:07 PM
AudiSport101
13
Jul 15, 2005 01:29 AM
Atomic864
Jun 7, 2003 03:09 PM
