Intermittent AC problems...
Old Jun 28, 2010 | 09:48 AM
schmod's Avatar
Default Intermittent AC problems...
I've been having an odd problem with my A4's air conditioner.
When I start the car, I get cold air for about 30 seconds before the AC compressor cuts out, and the blowers start venting hot air into the cabin.
If I wait a few minutes, and press the "snowflake" button twice to reset the compressor, I get cold air again. Sometimes this is enough to make it stay on, sometimes not. Because I can usually eventually get it to work, I'm assuming there's no coolant leak.
This problem only manifests itself when the outside temperature is above 90 degrees.
Am I to assume that the AC Clutch Relay is the most likely culprit? How can I confirm this diagnosis, and replace the relay?
(I have a 1999.0 B5 A4 2.8 with 146k miles. I'm not particularly enthusiastic about throwing a lot of money at this problem)
Old Jun 29, 2010 | 04:18 AM
waspie's Avatar
if you can get it to fail in your driveway probe the clutch wire with a multimeter. if its getting 12v and the inner hub of the compressor isnt turning it could be the clutch coil or the "air gap" is too wide. start there
Old Jun 29, 2010 | 06:02 AM
AudiMick's Avatar
Sounds like the high pressure switch is tripping. If the condenser is too hot it will trip. Are both the mechanical and the two speed electric fan running (on both high and low speeds)?
There's a switch in the radiator that controls the fan/ speed.
Check to make sure the airflow through the condenser isn't blocked, it's in front of the radiator so hose it down.
Old Aug 16, 2010 | 08:03 AM
schmod's Avatar
Update: Looks like you were right! My mechanic confirmed that my auxiliary fan isn't running, and quoted $300-$400 to get it fixed.
Browsing through the rest of the forum, this is evidently a somewhat difficult repair to DIY, so I may just have to tough it out for the rest of the season. Le sigh...
Old Aug 19, 2010 | 04:19 AM
waspie's Avatar
well, it'll only really be a problem when you're not moving or if its really hot out and you're at idle or driving slowly. once you're moving and enough air is getting through the front of the car the pressures will come down. have you ever taken the front end of the car off? if you have its not a terrible job. there's an a6 in the yard near me with the aux fan in it if you need one. did he check all wiring/fuses to be sure the actual fan motor is bad?
Anthony Sarrouf
Q7 MK 1 Discussion
Sep 21, 2017 05:37 PM
Anthony Sarrouf
Q7 MK 1 Discussion
Sep 18, 2017 08:41 PM
rallygarage
Audi Original "S" Cars
Apr 29, 2008 07:27 PM
peterklos
Nov 2, 2007 04:45 AM
Orlando 4000S
May 7, 2007 10:14 AM
