Just checking...
Old Oct 25, 2006 | 07:51 AM
EricBss7_CT's Avatar
Default Just checking...
Last night I go to unlock my doors with the remote. Alarm de-activiates, but doors stay locked. Unlock door manually. Shut the door. Hit the lock button on the remote, alarm activates, door stays unlocked. So I'm guessing I need a new central locking pump?
Old Oct 25, 2006 | 07:56 AM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
Well, what happens when you try to use the key, or the lock button inside the car?
Old Oct 25, 2006 | 08:13 AM
kenny (dremel)'s Avatar
Pull out the lock pump and look at it. Take you 5 minutes to find out if it's busted.
Old Oct 25, 2006 | 08:49 AM
AudiLife's Avatar
Default Well looking at it won't tell you much...
The way I could tell when my door lock pump went bad was when I had to unlock and lock the doors manually. The remote, and unlock button did not do anything. However when the remote lock button was pressed, the alarm would arm, but the locks wouldn't go down. How about fuses?
Old Oct 25, 2006 | 08:58 AM
RKA's Avatar
RKA
AudiWorld Uber User
Default I think he means look inside the pump...
there will be a shattered disc inside if it's broken. Common mode of failure for these things.
Old Oct 25, 2006 | 09:13 AM
Default Lock button inside the car does nothing either. Sorry, forgot to mention.
The key opens only the driver side door and disarms the alam as well when I put it in the keyhole.
Old Oct 25, 2006 | 09:37 AM
Yep. If you pull it out and it sounds like a box of cracker jack, then it's time for a new pump.
Old Oct 25, 2006 | 10:17 AM
Head Cat Herder
25 Year Member
Did you check all fuses?
Old Oct 25, 2006 | 12:46 PM
Nope, not yet. I will though before pulling the pump. Thanks for the suggestion.
Old Oct 25, 2006 | 03:19 PM
slightly disgruntled's Avatar
Default Try to lock the doors while inside the car, you should hear a long whining sound form the right rear
I always thought that it was the fuel pump, until the damn thing broke and the whining got longer...
It tries to lock the doors longer, but can't and throws a code and shuts off. (I think this is what happens when the plastic piece fails.) Use a VAG tool to be sure. The dealership might do it for free. I'd check before trying though.
USe-car
TT (Mk3) Discussion
10
Jan 23, 2019 02:03 PM
jeffmel79
Aug 8, 2014 07:04 PM
sgupta126
Sep 9, 2008 06:01 PM
trevor51590
Dec 2, 2007 06:05 PM
S4fastaudi
Aug 17, 2004 05:33 PM
