Lambda Problems again - anyone got the solution?
I saw a number of people with similar problems on the forum but did not find anyone that said they had found the solution. I was wondering if anyone did find a solution to the problem. I would like to fix it if possible. The "Check Engine" light
isn't much help when it's on all the time.
My error code is:
16545 - Oxygen (Lambda) Sensor B2 S2: Heating Circuit Malfunction P0161 -
92 -00 - Unknown Error Elaboration
I was told by a shop it was in that the heater on the probe was not
getting power. Cleared the light, but it comes back on as soon as the
engine exceeds 2000 rpm.
I have replaced the entire sensor with a correct one but that did not
solve it (that was before the second shop told me that there was no power
to the heater).
I am going to check all the fuses with a test light to see if that shows
anything, but after that I am out of ideas.
Thanks,
Benedikte
hope this helps.
sounds like your o2 sensor is dead that or you have an electrical problem on your hands.
-richard
