Lemmiwinks and USB
be careful. there not always as functional as real com ports...
I have had several problems with that at work and I have yet to get a vag-com working over an usb-serial converter.
I have the USB HEX-CAN cable and VAG-COM works...
with it, I have also found on ross-tech info about setting the com driver to a diffirent USB port.
Just trying to find all info I can regarding Lemmiwinks<ul><li><a href="http://www.ross-tech.com/vag-com/usb/virtual-com-port.html">http://www.ross-tech.com/vag-com/usb/virtual-com-port.html</a</li></ul>
Is the usb hex-can truly usb or just com simulation over usb?
If you bought it with the usb converter built in, they probably gave you a compatible tool with the right drivers. If you do the conversion on your own, you might end up pulling your hair out trying to figure out why it wouldn't work.
mosmoe (OPG)
08-21-2008 01:53 PM
reza
11-15-2004 08:30 PM
Zaphod//TMK:Indukted
23
01-08-2003 10:02 AM
