Lets try this again...
Old Nov 6, 2002 | 07:56 AM
DAP@EPL's Avatar
Audiworld Sponsor
Default Lets try this again...
Ron_C's GF's A4 has been throwing a "System Too Lean" DTC. We did some logging, cleaned the MAF with isopropyl alcohol and did some more logging. Here are the results.
<img src="http://pictureposter.audiworld.com/6924/a4_maf.jpg">
Obviously the MAF cleaning made a difference. However, the O2 Sensor learning values are still out of whack. What is a typical peak value for a MAF sensor in a chipped A4 1.8T?
-Dave Pramanik
Old Nov 6, 2002 | 08:03 AM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
Default Does the Bentley give you any baseline numbers to compare what you are getting to?
I don't have mine here at work, or else I would look it up for you..
Old Nov 6, 2002 | 09:01 AM
WYSIWYG's Avatar
detach and inspect the intake hose (also intake to bpv). any leak there will cause lean conditions
Old Nov 6, 2002 | 09:19 AM
DAP@EPL's Avatar
Audiworld Sponsor
Default I can check when I get home...
but the car is chipped so Bentley numbers might not be that useful. Then again, if Bentley says 150 g/s is normal for stock A4, we'd know that a chipped A4 should be higher than that.
I was hoping someone on the forums had done some MAF logging and could provide some insight.
-Dave Pramanik
Old Nov 6, 2002 | 10:32 AM
blk18tq's Avatar
Default Re: Lets try this again...
dont use isopropyl alcohol, not a good idea!
i had the same problem and used componet (electronic) cleaner from fry's, to clean the maf, then cleared the code and it never came back.. try that...hope its not to late since you already used alcohol and might of damaged the maf.
Old Nov 6, 2002 | 11:03 AM
DAP@EPL's Avatar
Audiworld Sponsor
Default Why would isopropyl alcohol damage the MAF?
That seems to be what most people are recommending for MAF cleaning. And it obviously helped since MAF values increased after cleaning.
Electronic cleaner is probably the next step before buying a new MAF, but we REALLY want to know what ideal MAF values are so we know if the MAF is actually bad (and how bad it is).
-Dave Pramanik
gturnerws
Dec 30, 2008 08:33 PM
Crisqo09 T.O.
Apr 16, 2005 09:55 PM
S4@last!::Now B7 RS4
Rocky Mountain Discussion
May 18, 2004 02:05 PM
+pressure
Oct 13, 2003 05:11 PM
M3iRiSH
Jul 13, 2002 08:11 AM
