MAF Problems???
Old Sep 22, 2003 | 06:18 PM
A4Turbo22's Avatar
New Member
Default MAF Problems???
Well, for the past couple of weeks I have been having some regular turbo problems. It first started off with my A4 not boosting past 4-5psi when the car became heated up, then it started happening all the time. After VAGing the car, it said N75 open circuit, so I replaced the N75, and I was boosting up to normal 15psi, but the day of replacing it, I was driving home from work, and pulling away in 3rd gear, the car stuck at 5psi, and the boost then became very erratic there after. Then, a few miles down the road, my Check Engine light came on. I limped home, and checked things under the hood. Turns out, I had not tightened the hose connecting the MAF to the turbo inlet, so I tightened that up, and now the car will not boost past 5psi. I am thinking it is the MAF now, is there any way to check if this is the problem? Need some advice from the experts!
Old Sep 22, 2003 | 06:27 PM
Yippers®'s Avatar
Member
Try resetting the ECU and do a TBA
Old Sep 22, 2003 | 06:28 PM
[tri]liament's Avatar
if your CEL is on, get a VAG and check out the DTCs
Old Sep 22, 2003 | 06:42 PM
A4Turbo22's Avatar
New Member
Default Re: Try resetting the ECU and do a TBA
I did unplug the ECU, and did the TBA, but that did not solve the problem, and strange enough, it did not clear the CEL either.
Old Sep 22, 2003 | 06:50 PM
Yippers®'s Avatar
Member
Default Then you need to have the code pulled. If the CEL remains there is a hard fault still present and
knowing the code will allow a better shot at the cause.
Old Sep 23, 2003 | 09:40 AM
improved just pino's Avatar
Default i've had the same issues as you have had...
i think it might be my MAF, not sure.
firstarsbrnwhite
Jan 18, 2009 09:48 AM
The R
Jun 24, 2005 09:25 AM
blueT28EnYcEe
Jun 12, 2002 05:04 AM
ivansis
Sep 19, 2001 08:27 AM
