Mandrel bent VS Crush bent**
i konw the difference in appearance, but wat's the difference in performance wise?? let's say both in 2.5".
true... (more)
but none of the bends on the A4 are sharp enough to get that much of a decrease. As exhaust systems go, its a pretty straight shot, so the loss w/ a non-mandrel system is not as bad as it could be on another car. To compensate, just go with a slightly larger diameter- if you want a custom system to compare with a 2.5inch mandrel system, use 2.75inch piping in a crush-bend system. I have a 3inch crush bend system (custom) that flows much more than my old 2.25inch mandrel bent borla.
are u running K04?
but i am running a stock turbo with chip and some basic stuff, so u recommend me to get the 2.75 in a crush bent system rite? coz no one can do mandrel bent here in Vancouver BC. also wat steel of your piping are u using? stainless or aluminized steel?
Re: are u running K04?
yes i am. Three inches for you would prolly be overkill, but 2.75 would be fine for you. I'd estimate the flow of a crushed 2.75 to be similar to a mandrel 2.5 (rough estimation, i have no facts about that). Best thing is you could prolly do it for way less than a mandrel bent 2.5 inch system. As for metal, i used aluminzed pipes, but stainless steel components (SS muffler, resonator and cat, and SS flex piece). Below is my post when i had the system done...<ul><li><a href="https://forums.audiworld.com/a4/msgs/1282571.phtml">custom exhaust</a></li></ul>
SilS4
08-14-2000 03:07 PM
