Which Mintex Redbox Pads?
For the front pads for a 2001 A4 1.8T sedan, APR lists Mintex part number 1826 while AWE Turning lists part number 1531. APR suggests using 1531 for up to MY2000 but not for MY2001.
Anyone know who is right and/or what the difference is between the 1531's and the 1826's?
The Mintex website was no help.
Thanks.
~Gordon
Thanks.
~Gordon
the difference may be the pad wear sensor... one has it, the other does not
Check with the retailer to see if the ones you are about to buy are equipped with the pad wear sensor.
The connector on the Mintex is not the same for your Audi, so if you want to use it, you have to splice in the one from your used factory pads.
Otherwise, you can go without and short the wires on your car to trick the car into thinking the connector is attached.
Hope that helps.
PeteH
Hope that helps.
PeteH
Re: the difference may be the pad wear sensor... one has it, the other does not
Thanks. Both APR and AWE claim that the pads have the wear sensors so that isn't the difference (unless there is a connector difference between the two pads).
I did not know that the Mintex connector was different than on the stock pads so I did learn from your post!
~Gordon
~Gordon
1531=round sensors, 1826=oval sensors, both are in stock for...
$55.00
Tom
ECS Tuning
800/924-5172
40+ years & counting of tuning the finest automobiles
in the world, namely V/W & Audi
Tom
ECS Tuning
800/924-5172
should be the oval, they are in stock
Tom
ECS Tuning
800/924-5172
Tom
ECS Tuning
800/924-5172
Re: should be the oval, they are in stock
Thanks! I'll be calling you guys tomorrow. If I had been planning better I would have ordered these from you guys at the same time as I got my 8mm spacers from you a month or so ago.
~Gordon
~Gordon
Ok, sound good!
Tom
ECS Tuning
800/924-5172
Tom
ECS Tuning
800/924-5172
EGainer
09-12-2004 06:00 PM
phkodack
12-25-2003 06:59 AM
Rich W
07-06-1999 10:11 AM
