monitoring injector pulsewidth
Old Mar 25, 2011 | 10:53 AM
gregp1962's Avatar
Default monitoring injector pulsewidth
I'm wanting to set up a monitor to see the injector pulsewidth in real time. I think I can do that by attaching an dwell meter to one of the injector wires. Does anyone know if this will work? I have both a 2.8 and a 1.8t. I could do it on either car.
Old Mar 26, 2011 | 08:28 AM
turbo510's Avatar
I don't know about a dwell meter (which reads out in crankshaft degrees) but you could with an oscilloscope. Why not just use VAG-COM to see the pulse widths?
Old Mar 29, 2011 | 01:32 PM
gregp1962's Avatar
I don't have a VAG COM or oscilloscope. This dwell meter is small and handy. Shouldn't it read the pulse width if correctly connected to one of the injectors?
Old Mar 29, 2011 | 01:52 PM
turbo510's Avatar
The dwell meters that I'm aware of show the ratio of time for contact open vs. contact closed, expressed in degrees, where you have to select the number of cylinders for the reading to be correct. Using a dwell meter would be a hard way to measure pulse width IMHO. What are you intending to do with the pulse-width measurements?
sosoomi
Mar 2, 2019 04:47 AM
Waggin
VAG-COM Discussion
Jun 7, 2006 08:41 AM
BrokenRocket
May 16, 2005 01:36 PM
mAd1(gt3071r)
Mar 2, 2005 08:31 AM
azblake
Feb 13, 2004 08:46 PM
