Which N75 should I use? F, H, or J? 2000 1.8TQM w/ GIAC
My only mods are a GIAC chip and a 710N diverter valve. I have been having an occasional surging issue at partial throttle and have been logging an intermittent charge pressure control negative deviation. I have no leaks. I probably have the older C version valve which was known to go bad. Which version wastegate valve should I get as a replacement?
H is most reliable from what I hear...
There was a poll over at passatworld.com... H was best in regards
to providing power like the J but more reliable.
Be forewarned, you may be swapping them out to see what works
best for you. Many folks resorted back to stock because of
issues from non-stock valve.
I'm leaning towards the (stock) F
I haven't pulled my old one, but I bet when I do it will be the older 'C' version which was discontinued and replaced with the F. I want the valve that will provide the smoothest throttle response throughout the rpm range.
That's a wise choice... I would also stick to stock or as close to stock as possible.
However, if you were interested in gaining more power, you could
try the H as a safer bet than the rest.
If the car is 2000 or newer, there's no gain to be had.
The 2000+ A4 1.8Ts have a MAP sensor, the ECU adjusts duty cycle down to compensate for the more agressive N75s. All you end up with then is a boost spike followed by a valley which might actually make the car slower, plus less smooth part throttle.
It should be... (more)
If your original N75 was failing, that would explain the increase in performance switching to a new valve.
The other caveat is the tune. Most tuners use PID ( <a href="http://en.wikipedia.org/wiki/PID_controller">http://en.wikipedia.org/wiki/PID_controller</a> ) to control the boost on stage 1 and 2 chips on cars w/ OEM MAP sensors. If you're running a tune which was developed in a way where the N75 duty is hard-coded and doesn't compensate with MAP sensor input, you would see more boost.
I would suggest logging blocks 003, 114, and 115 with a properly working OEM valve and your upgraded valve. I'd be curious to see the results.
