Need help with ECU
Old Jul 8, 2009 | 01:41 PM
Jim TT's Avatar
Default Need help with ECU
I have a 1998 A4q 1.8t and I think the ECU is bad; I would like to try a good one but don't know anyone with my type off car. If you are in the Naperville Il. (west Chicago) area and would help me out I will return the favor (I do all kinds of work on Audis and VWs) ; I have helped a dozen guys with thier timomg belts on these forums. JIM
Old Jul 8, 2009 | 01:57 PM
Nate (ETKA+Scumbag)'s Avatar
Keeper of the Cash
Tech Guru
Why do you think the ECU is bad? What diags did you do to come to that conclusion? What problems are you having? Have you checked for codes?
Old Jul 9, 2009 | 05:31 AM
Jim TT's Avatar
Why do I think it is bad:
1.Cannot scan UCU / ecu not powering up
2. Bat is 12v and good
3. 12V to both power pins of ECU
4. No CEL when ign powered up.
5. Car cranks fine will not start,
6. Fuel pump and relay good.
7. no after market wiring and I have an OEM radio
Any ideas? I would like to try a known good ECU at this point or I will think about buying a used one. JIM
Old Jul 9, 2009 | 05:59 AM
Jim TT's Avatar
Is there no way to edit threads anymore? Anyway point 1. should read 'cannot scan ECU'.
Old Jul 9, 2009 | 06:36 AM
Keeper of the Cash
Tech Guru
Good reasons. Is it chipped? Could be a solider issue. I'd open it up and check it out at this point.
Old Jul 9, 2009 | 06:38 AM
Keeper of the Cash
Tech Guru
You have to ask Kris for editing rights first.
Old Jul 9, 2009 | 03:56 PM
nat1971a's Avatar
I think i have the same problem.
Bought a fresh water damaged audi a4 1999 1.8Turbo recently as a project to work on....
the symptoms i have is that the immobiliser light is on...no check engine light....presumably because it cant talk to the ECU. And obviously the car doesnt start.
Can't connect to the ECU via the diagnostics port....
I opened up the ECU and there was a little corrosion....so i have ringing around to try and get some prices on a replacement....
Cheers,
Nat
Rosati (Ginzo)
May 3, 2007 09:41 AM
zeus1
Sep 19, 2004 10:01 AM
Original Velvet
Jun 24, 2004 02:34 PM
acidrane-teh jeweler
VAG-COM Discussion
Apr 28, 2004 06:41 PM
mroberts
Jul 16, 2003 12:02 PM
