Need help with O2 sensor
Old Apr 4, 2003 | 11:02 AM
ThirdEye's Avatar
Default Need help with O2 sensor
I was reading the how to for replacing the o2 sensor and they were referring to the 3 wire version not the 4 wire version because the A4 12valve had a 3wire sensor and I accidentaly bought the 3 wire version even though my car has 4wire. My old sensor had 2 white, 1 black and 1 gray cable and the new one had the same except it was missing the gray one. I read that the extra cable is just a ground so I hooked up all the cables coming from the ECU correspondingly to the 3 wire o2 sensor and grounded the extra cable from the ecu to the negative terminal of the battery because I read here that it is just a ground cable. Now I have a check engine light. Can someone please advise on what to do and what I did wrong? Thanks!
Old Apr 4, 2003 | 11:31 AM
OttawaA4Can's Avatar
Default ground doesn't mean negative side of the battery...
you can connect it to any solid part of chassis.. the entire chassis is ground.... dont' know if this will help...
Old Apr 4, 2003 | 11:34 AM
birdsong's Avatar
Default Re: ground doesn't mean negative side of the battery...
Heh, and the ground runs back to the negative side of the battery. One and the same, really.
Old Apr 4, 2003 | 01:34 PM
Audi2ptzero's Avatar
Elder Member
Default A 3 wire 02 sensor is a post-cat sensor not pre-cat.
Go buy the correct 4 wire sensors.
Raudi_6 akaDeutschMF
Dec 28, 2007 04:22 AM
TTransport
Dec 30, 2006 12:30 PM
radioboard
Audi Original "S" Cars
Nov 20, 2006 05:35 AM
ThermalX
Aug 22, 2004 10:31 AM
Darius
Performance and Tuning
Mar 31, 2003 09:29 AM
