Need help With Vag Com Trouble codes
3 Faults Found:
17956 - Boost Pressure Regulation Valve (N75): Open Circuit
P1548 - 35-00 - -
16885 - Vehicle Speed Sensor: Implausible Signal
P0501 - 35-10 - - - Intermittent
16839 - EVAP System: Large Leak Detected
P0455 - 35-00 - -
Readiness: 0000 0000
1 Fault Found:
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
30-00 - Open or Short to Plus
3 Faults Found:
00588 - Airbag Igniter; Driver Side (N95)
32-10 - Resistance too High - Intermittent
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
3 Faults Found:
So any help with the other ones would be great, much appreciated.
