Need to remove front bumper. Any instructions on this
EASY.....
2 hex bolts need to be removed..they are located just above the lower grills and drive upward into the bumper. Once those are removed, pull bumper forward, then you will need to unhook the line that goes to the washer fluid reservior. It is a snap fitting,and pops off easy. BUT first you need to clamp down the headlight washer line so that the fluid doesn't drain all over. That should do it.
IIRC the APR snub mount install instructions (pdf file) gives a pretty fair description.
<ul><li><a href="http://www.goapr.com/support/index.html">http://www.goapr.com/support/index.html</a</li></ul>
DesmoTesta
9
04-21-2008 06:26 AM
thomas1978
03-30-2005 05:28 AM
Audi4orce
02-02-2001 08:18 AM
