Need TT Install help...PLUS GOOD NEWS...
I got around to doing my greedy TT III install this past weekend with the write up in the URL below...the good news is that Kitch's write-up works...
it's very easy to tap the OBD wire and everything...TT works great but I have a question on how to fool the alarm system...
which one of the wires from this mess is for the central locking system? Can anyone help me with what I need to do to trick the system? Is the 1.8t A4 fuse pannel the same as the S4? Is the central locking wire gonna be the same?
<img src="http://www.ncaudi.org/jake/photos/Blitz/images/PB140006.jpg">
TIA!<ul><li><a href="https://forums.audiworld.com/s4/msgs/1031992.phtml">https://forums.audiworld.com/s4/msgs/1031992.phtml</a</li></ul>
did you read this?
this writeup has all the wires that you need, ive done numerous tt installs using it.<ul><li><a href="https://www.audiworld.com/tech/elec31.shtml">https://www.audiworld.com/tech/elec31.shtml</a</li></ul>
it's the same wire
its the back of fuse 6, its the same wire desribed in the write up below. just run it to post 75x like Kitch says instead of the wire behind the cluster, much easier and worked fine for me.<ul><li><a href="https://www.audiworld.com/tech/elec31.shtml">https://www.audiworld.com/tech/elec31.shtml</a</li></ul>
