New Tweeters didnt fix bad front left tweeter - Is the amp bad?
I was experiencing bad sound from my front left tweeter. I replaced the tweeters with new infinity 2ohm units. This did not fix the problem.
So now i am assuming, from reading some other threads, that my amp has issues.
Anyone know how to fix the amp? Are there components on the amp i can replace to fix this issue.
While i am no electrical engineer, i am quite comfortable soldering circuitry.
2000 S4 w/ Bose Symphony
Re: New Tweeters didnt fix bad front left tweeter - Is the amp bad?
front speakers are powered off the headunit. And front speakers are 4ohm regardless of bose or non bose as well i think. It was only the rear that were 1.5 ohms or so. The tweeters are wired to the door speaker i think. Swap speakers with the other door, if the bad sound follows than its the speaker that is bad.
<center><img src="https://www.audiworld.com/tech/pix/connector.gif"></center><p>On the 2000 Bose System, all of the channels go through the amp in the back. (see attached image).
Your correct that the tweeter is wired to the door speaker. I did swap the speakers and i have the exact same issues.
At low volumes, the speaker sounds very scratchy. With higher volumes, it becomes less noticable.
<center><img src="http://www.nav-plus.com/instructions/images/symphonyiidiag.jpg"></center><p>Im looking at this. I remember the 00+ A4/S4 used the symphony headunit.
I think you are looking at the rear door speakers that are going to the amp.
BSK auf Arbeit
03-23-2005 10:33 AM
manuva
08-23-2004 03:08 PM
